Hotfixes for opsi-client-agent in stable and testing
Dear opsi users,
for the Windows versions of the opsi-client-agent
4.1.1.1-1 (testing)
4.1.0.0-47 (stable)
as published in the release of 25.09.2020
there were various complaints about lengthy installation times.
The problems are due to file permissions repairs.
We have now added these repairs (administrable via properties)
and turned them off in places that are relevant and where we can replace them.
We hereby release these hotfixes for both packages
in testing and stable which at least mitigate significantly the problem.
Beyond this hotfix we are still working to actually improve the installations speeds even further.
************* ATTENTION ** ATTENTION *******************************
In order to install the testing version of the opsi-client-agent,
the opsi-client-kiosk must be installed BEFORE.
The reason being that the product opsi-client-kiosk can only be installed in such a way
that can take over from an old opsi-client-agent
If no opsi-client-kiosk product is installed on the opsiserver,
the opsi-client-agent >= 4.1.1.1 cannot be installed.
We are working on this problem as well.
Updated packages in testing:
Windows Localboot packages:
* opsi-client-agent (4.1.1.1-2)
Updated packages in stable:
* opsi-client-agent (4.1.0.0-48)
with kind regards
detlef oertel
Here comes the
Changelogs
opsi-client-agent (4.1.1.1-2) testing; urgency=low
* new property: fix_rights_on_c_tmp (default=false)
* new property: fix_rights_on_wan_cache (default=false)
* new properties are used to control and speed up the setup of access rights
* Log setacl actions on loglevel 6
-- Detlef Oertel <d.oertel@uib.de> Fri 25 Aug 2020:15:00:00 +0200
opsi-client-agent (4.1.0.0-48) testing; urgency=low
* backport patch_config_file.py with domain from backend from version 4.1.1.1
* backport postinst patch for opsi 4.2 from version 4.1.1.1
http://www.opsi.org
