updates have been released for opsi 4.1 in testing.
With the general availability of winexe for the distributions supported by the opsi 4.1 server OSes winexe has been added as a dependency in opsi-windows-support.
opsi-admin gained support for the configuration of connection data (address, username, password) in a file so that configuring this on the commandline is not required anymore.
A blogpost explains background information.
More information can be found in the manual.
The overview page of the opsiconfd has been overhauled.
There is now a simpler selection for downloading the configed installer that reacts to the used OS.
Translations for opsi-admin can be made in Transifex as usual.
Updated packages in testing:
Server packages:
- opsi-directory-connector 28-1
- opsi-linux-bootimage 20190227-1
- opsi-utils 4.1.1.30-1
- opsi-windows-support 4.1.1.8-1
- opsiconfd 4.1.1.18-4
- python-opsi 4.1.1.62-1
Linux localboot packages:
- opsi-configed 4.1.1.0.5-2
With kind regards
Niko Wenselowski
PS: Changelogs:
opsi-configed (4.1.1.0.5-2) TESTING; urgency=medium
* updated bundled java versions
-- Rupert <r.roeder@uib.de> Fri, 18 Feb 2019 13:11:46 +0100
opsi-configed (4.1.1.0.5-1) TESTING; urgency=medium
* option to extend product groups so that they include all dependent products
-- Rupert <r.roeder@uib.de> Fri, 13 Feb 2019 13:11:46 +0100
opsi-configed (4.1.1.0.4-1) STABLE; urgency=medium
* permission options added for host group permission, create client permission, product group permission
* support for upload of 4.1. repo files
-- Rupert <r.roeder@uib.de> Fri, 01 Feb 2019 13:11:46 +0100
opsi-configed (4.0.7.8.7-1) STABLE; urgency=medium
* info window if the opsiconfd version is not more supported
* on login page info about the java environemnet
-- Rupert <r.roeder@uib.de> Tue, 22 Jan 2019 13:11:46 +0100
opsi-directory-connector (28-1) testing; urgency=medium
* When creating an client set the date for lastseen to zeroes to make
newly created clients that haven't been in contact yet easy to spot.
* Removed parts meant for handling sync of empty groups.
This deprecates the configuration settings mapping.groups and
directory.search_query_groups from the configuration file.
* Internal refactorings.
-- Niko Wenselowski <n.wenselowski@uib.de> Mon, 10 Dec 2018 13:39:24 +0100
opsi-directory-connector (27-1) testing; urgency=medium
* Internal restructuring.
-- Niko Wenselowski <n.wenselowski@uib.de> Mon, 19 Nov 2018 12:30:38 +0100
opsi-linux-bootimage (20190227-1) testing; urgency=medium
running rngd twice
corrected typo in master.py
opsi-linux-bootimage (20190218-1) testing; urgency=medium
kernel 4.20.8
-- Mathias Radtke m.radtke@uib.de Mon, 18 Feb 2019 12:38:41 +0100
opsi-utils (4.1.1.30-1) stable; urgency=medium
* opsi-admin: Only show error message about reading session information
if an session file exists.
* opsi-admin: Added support for using an opsirc file via --opsirc.
* opsi-admin: History and session ID are now stored in ~/.opsi.org/
-- Niko Wenselowski <n.wenselowski@uib.de> Tue, 19 Feb 2019 17:07:15 +0100
opsi-utils (4.1.1.29-1) stable; urgency=medium
* opsi-admin: Fix bug in calling task
setActionRequestWhereOutdatedWithDependencies.
This method remains obsolete and the corresponding method should be used.
* opsi-admin: Logfile in interactive mode will use loglevel 7.
* opsi-admin: Set default loglevel to 3.
* opsi-backup: Small internal refactoring.
* opsi-package-updater: Improved text for --help.
-- Niko Wenselowski <n.wenselowski@uib.de> Thu, 07 Feb 2019 16:53:11 +0100
opsi-windows-support (4.1.1-8) testing; urgency=medium
* Winexe now a dependency also for CentOS/RHEL
-- Mathias Radtke <m.radtke@uib.de> Wed, 06 Feb 2019 09:31:24 +0100
opsi-windows-support (4.1.1-7) testing; urgency=medium
* corrected RPM requirement for CentOS/RHEL
-- Mathias Radtke <m.radtke@uib.de> Tue, 22 Jan 2019 09:30:00 +0100
opsi-windows-support (4.1.1-6) testing; urgency=medium
* added dependency: winexe
-- Mathias Radtke <m.radtke@uib.de> Mon, 21 Jan 2019 12:17:53 +0100
opsiconfd (4.1.1.18-4) stable; urgency=medium
* Overview page: Automatic selection of download link per requesting OS.
* Info page: Place the logo above the heading.
-- Niko Wenselowski <n.wenselowski@uib.de> Thu, 21 Feb 2019 16:17:16 +0100
python-opsi (4.1.1.62-1) stable; urgency=medium
* Opsi.Util.File.Opsi.Opsirc: Change the default path for an opsirc file
to ~/.opsi.org/opsirc.
-- Niko Wenselowski <n.wenselowski@uib.de> Tue, 19 Feb 2019 16:58:20 +0100
python-opsi (4.1.1.61-1) stable; urgency=medium
* OPSI.Util.Task.UpdatePackages.Updater.getLocalPackages: When looking for
the checksum file use the absolute path.
-- Niko Wenselowski <n.wenselowski@uib.de> Mon, 18 Feb 2019 10:53:33 +0100
python-opsi (4.1.1.60-1) stable; urgency=medium
* OPSI.Backend.MySQL: Fixed a reference error.
* OPSI.Util.File.Opsi.Opsirc.readOpsirc: Skip empty values from config.
* OPSI.Util.File.Opsi.Opsirc.readOpsirc: Mark passwords as confidential
right after reading.
* OPSI.Util.File.Opsi.Opsirc.readOpsirc: filename parameter is optional.
If None is given it will resort to retrieving the path via
getOpsircPath.
-- Niko Wenselowski <n.wenselowski@uib.de> Fri, 15 Feb 2019 13:07:20 +0100
python-opsi (4.1.1.59-1) stable; urgency=medium
* DhcpOnDepot Feature-Fix: (fixes #3901)
* Added module OPSI.Util.File.Opsi.Opsirc
-- Erol Ueluekmen <e.ueluekmen@uib.de> Fri, 08 Feb 2019 15:15:29 +0100
