updated opsi 4.1 packages in stable & testing
News and announcements
Dear opsi users
hereby we release updates in opsi 4.1 stalble and testing
In addition we have the following information:
  • The opsi-script 4.12.1 documentation has been updated
  • Support for Windows 10 1903 is public in the current testing packages (e.g.win10-x64_4.1.0.0-16)
  • Reminder for swaudit: With the use of the license management extension adjustments might be necessary for windows 10 pools
  • The new jedit package runs on Windows an Linux and therefore replaces the older l-jedit package
Regards
Updated packages in stable:
server packages opsi 4.1:
* opsi-utils (4.1.1.32-1)
* pyhon-opsi (4.1.1.65-1)
* opsi-nagios-plugins (4.1.1.5-1)
* opsi-script (4.12.0.35)
Linux Localboot packages:
* l-desktop (4.1.0.5-1)
* l-opsi-server (4.1.1.10-5)
Windows Localboot packages:
* opsi-script-test (4.12.1.0-1)
* opsi-template-with-admin (4.1.0.0-2)
* opsi-client-agent (4.1.1.0-29)
Windows/Linux Localboot packages:
* swaudit (4.1.0.0-3)
* jedit (5.5.0-6)
* opsi-winst (4.12.1.2-1)
* opsi-configed (4.1.2.0.4-1)
updated packages in Testing:
* opsi-utils (4.1.1.32-2)
* pyhon-opsi (4.1.1.66-1)
* opsi-linux-bootimage 20190522-1
* opsi-script (4.12.1.2)
* opsi-client-agent (4.1.0.0-29)
* config-win10 (4.1.1-6)
* opsi-linux-client-agent (4.1.0.17-1)
Linux Netboot packages:
* ubuntu16-04 (4.1.0.1-3)
* debian9 (4.1.0.2-5)
opsi-local-image Localboot packages:
* win10-sysprep-app-update-blocker (4.1.0.0-1)
Windows Netboot packages:
* win10 (4.1.1.0-16)
* win10-x64 (4.1.1.0-16)
* win10-captured (4.1.1.0-16)
* win10-x64-captured (4.1.1.0-16)
opsi-local-image Netboot packages:
* opsi-local-image-win10 4.1.0.0-16
* opsi-local-image-win10-capture 4.1.0.0-16
* opsi-local-image-win10-x64 4.1.0.0-16
* opsi-local-image-win10-x64-capture 4.1.0.0-16
* opsi-vhd-win10-x64 4.1.0.0-16
* opsi-winst 4.12.1.2-1
* opsi-script-test 4.12.1.0-1
* opsi-template-with-admin 4.1.0.0-2
* jedit 5.5.0-6
* swaudit 4.1.0.0-3
* windows10-upgrade 19.03-1
* opsi-client-agent 4.1.0.0-28
Changelogs:
opsi-utils (4.1.1.32-2) stable; urgency=medium
* RPM: Change access rights for logrotate configs to 644.
-- Niko Wenselowski <n.wenselowski@uib.de> Fri, 17 May 2019 13:41:05 +0200
opsi-utils (4.1.1.32-1) stable; urgency=medium
* opsi-newprod: Fix naming interpreter in shebang line in templates for
preinst and postinst.
-- Niko Wenselowski <n.wenselowski@uib.de> Tue, 30 Apr 2019 13:33:16 +0200
python-opsi (4.1.1.66-1) stable; urgency=medium
* OPSI.Backend.Backend: Only import MethodType from types.
* OPSI.System.Windows.execute: refactored showing output lines.
* 10_opsi.conf: setProductActionRequestWithDependencies small refactoring.
* OPSI.SharedAlgorithm: Adjusted loglevel for cases where unfulfillable
requirements are requested to make problems easier to spot.
* OPSI.Backend.JSONRPC.JSONRPCBackend: Defaults ports are now class
variables instead of instance variables.
-- Niko Wenselowski <n.wenselowski@uib.de> Tue, 14 May 2019 15:42:58 +0200
python-opsi (4.1.1.65-1) stable; urgency=medium
* Using thread.is_alive instead of thread.isAlive because the latter will
be removed in Python 3.8.
* hwaudit.conf: Change field for extClock from int to bigint.
* OPSI.Util.File.Opsi: Internal refactorings.
* OPSI.Util.Task.Backup: Internal refactorings.
-- Niko Wenselowski <n.wenselowski@uib.de> Fri, 03 May 2019 14:26:59 +0200
opsi-nagios-plugins (4.1.1.5-1) stable; urgency=medium
* Setting an User-Agent in our HTTP headers.
-- Niko Wenselowski <n.wenselowski@uib.de> Wed, 24 Apr 2019 11:57:11 +0200
opsi-nagios-plugins (4.1.1.4-3) stable; urgency=medium
* Fixed Typo.
-- Thomas Trapp <t.trapp@uib.de> Thu, 24 Apr 2019 10:48:45 +0100
opsi-script (4.12.0.35) stable; urgency=low
* osparser: producestringlist: getsublist: with whitespaces around numbers
-- Detlef Oertel <d.oertel@uib.de> Tue, 15 Jan 2019 15:00:00 +0200
opsi-script (4.12.0.34) stable; urgency=low
* osparser: producestringlist: getsublist: with string expression instead of numbers
* osparser: producestringlist: createstringlist: fix: empty strings as argument allowed
-- Detlef Oertel <d.oertel@uib.de> Thu, 10 Jan 2019 15:00:00 +0200
opsi-script (4.12.0.33) stable; urgency=low
* postinst: create config opsi-script.global.w10BitlockerSuspendOnReboot=false
* osconf: new config opsi-script.global.w10BitlockerSuspendOnReboot
* osconf: new global config variable: w10BitlockerSuspendOnReboot (default= false)
* osmain: buildPC: >=win 10 and w10BitlockerSuspendOnReboot and (txrImmediateReboot or txrImmediateReboot)
then suspend bitlocker for 1 reboot fixes: #3816
* new units oswmi, utilwmi
new function getListFromWMI(<wmi class str>,<property list>,<condition str>) : stringlist
example: set $plist$ = createStringList ('Model','Vendor')
set $list$ = getListFromWMI('Win32_ComputerSystem',$plist$,'where model like Esprimo%')
if <property list> is empty all properties of <wmi class str> will be returned
on error a empty list will be returned
-- Detlef Oertel <d.oertel@uib.de> Mon, 17 12 2018:15:00:00 +0200
opsi-script (4.12.0.32) stable; urgency=low
* osconf: no more OpsiServiceConfigs: in log
-- Detlef Oertel <d.oertel@uib.de> Thu, 25 10 2018:15:00:00 +0200
opsi-winst/opsi-script (4.12.1.2) stable; urgency=low
* add oslistedit to projectfiles
* fixes in oslistedit
* add osinputstring
* add new string function stringinput(< message str>,< boolstr confidential>)
* document randomIntStr(<>)
* fix on gettemppath
-- Detlef Oertel <d.oertel@uib.de> Fri, 12 Apr 2019:15:00:00 +0200
opsi-winst/opsi-script (4.12.1.1) stable; urgency=low
* fix in oswmi (give stringlist as stringlist)
-- Detlef Oertel <d.oertel@uib.de> Thu, 04 04 2019:15:00:00 +0200
opsi-winst/opsi-script (4.12.1.0) experimental; urgency=low
* integration of new xml functions:
* new units in common: osxml, osxmltdom, osxmlsections
* new section type xml2
* osparser: Tuibinstscript: new method doxml2patch:
* OpenNode <node path : string>
* DeleteNode <node path : string>
* setNodeText <text : string>
* setAttribute <name : string>, <value:string>
* addAttribute <name : string>, <value:string>
* delAttribute <name : string>
* adNewNode <name : string>
* gotoParentNode
* getXml2AttributeValueByKey(<xml node:stringlist>,<key:string>): string
* getXml2Text(<xml node:stringlist>) : string
* getXml2DocumentFromFile(<filename:string>) : <xml-doc:stringlist>
* getXml2Document(<pure xml :stringlist>) : <xml-doc:stringlist>
* getXml2UniqueChildnodeByName
* xml2GetFirstChildNodeByName(<xml-doc:stringlist>,<node name:string>) : <xml node:stringlist>
* xml2NodeExistsByPathInXMLFile(myfilename, path: string; attributes_strict: boolean): boolean;
* new regex functions:
* isRegexMatch(<string>, <pattern>) : boolean
* getSubListByContainingRegex(<pattern>, <target list>) : stringlist
* getSubListByContainingRegex(<pattern list>, <target list>) : stringlist
* getRegexMatchList(<pattern>, <target list>) : stringlist
* getRegexMatchList(<pattern list>, <target list>) : stringlist
* removeFromListByContainingRegex(<pattern>, <target list>) : stringlist
* removeFromListByContainingRegex(<pattern list>, <target list>) : stringlist
* stringReplaceRegex(<string>, <pattern>, <replacement string>) : string
* stringReplaceRegexInList(<target list>, <pattern>, <replacement string>) : stringlist
* new network functions
* isValidIP4 (<ip4adr>) : boolean
* isValidIP4Network (<ip4adr>, <netmask>) : boolean
* isValidIP4Host (<ip4adr>, <netmask>) : boolean
* getIP4NetworkByAdrAndMask (<ip4adr>, <netmask>) : string
* getDefaultNetmaskByIP4adr (<ip4adr>) : string
* new url related functions
* parseUrl(<url string>) : stringlist
* createUrl(<urlcomponents list>) : string
* macos related:
* getos detect macos as 'macos'
* osparser: new function GetMacosVersionInfo : string
* osparser: new function getMacosVersionMap : stringlist
* misc:
* ExtractFileExtension (`<path>`) : string [W/L]
* ExtractFileName (`<path>`) : string [W/L]
* DirectoryExists (`path`[,<accessstr>]) : boolean [W/L]
* osparser: new (undocumented) command 'setDebug_prog = (true/false)'
* osshowsysinfo: caption is Systeminfo (instead of SystemInfo)
* reencode(paramstr(0),'system')
* remove some svn entries
* replace unit osxbase64 by fpc unit base64
* Release now compiled with activated Checks for IO, Range, Overflow and Stack
* unit oscrypt with {$RANGECHECKS OFF}
* osparserhelper: fix in geouterfunction
* osdefinedfunction: isvisiblelocalvar: serach optimization
* osfunc: checkfileexists: use widechsr/utf16 for filenames
* osparserhelper: new function stringlistintersection (get stringlist intersection)
* new cli parameter /processproducts productId [,productId ]*
* added unit oszip
* osparser: fileActionsMain: zipfile, unzipfile
* new in file sections: zipfile <file or dir> <zipfile>
* new in file sections: unzipfile <zipfile> <targetdir>
* osparser: fix in Hasminimumspace
* osparser: fix searchpath from %opsiScriptHelperPath% to %opsiScriptHelperPath%\lib; fixes #3975
and createstringlist() gives empty list
* osparser: modified : getListFromWMI
* `getListFromWMI(`<wmi namespace str>,<wmi class str>,<property list>,<condition str>`) : stringlist`
* If <wmi namespace str> is empty, it defaults to `root\cimv2`.
-- Detlef Oertel <d.oertel@uib.de> Wed, 23 01 2019:15:00:00 +0200
opsi-configed 4.1.2.0.4
Changelogs
* bugfix in UserRoles, (not) allowed clients did not reappear
* new option "ignore ping answer" for opsi-deploy-client-agent call
* new option "use sudo" for opsi-deploy-client-agent call
* removed opsi 3 value for installation_status in the search function
opsi-linux-bootimage (20190522-1) testing; urgency=medium
* setting variable isWifi when connected to WiFi network
-- Mathias Radtke m.radtke@uib.de Wed, 22 May 2019 11:06:43 +0200
opsi-linux-bootimage (20190520-1) testing; urgency=medium
* added Intel, Broadcom and Realtek wifi drivers
* added Wifi fallback if ssid and password definded in bootimage.append
parameters
-- Mathias Radtke m.radtke@uib.de Mon, 20 May 2019 14:21:59 +0200
opsi-linux-bootimage (20190507-1) testing; urgency=medium
* kernel 5.0.13
* config files not overwritten
* python-opsi_4.1.1.62-1
-- Mathias Radtke m.radtke@uib.de Tue, 07 May 2019 08:20:25 +0200
opsi-linux-bootimage (20190325-2) testing; urgency=medium
* changed dependencies
-- Mathias Radtke m.radtke@uib.de Thu, 04 Apr 2019 10:33:51 +0200
opsi-linux-bootimage (20190325-1) testing; urgency=medium
* kernel 4.20.17
-- Mathias Radtke m.radtke@uib.de Thu, 04 Apr 2019 10:10:03 +0200
l-desktop 4.1.0.5-1 ; stable ; urgency=low
* Debian / Ubuntu: myspell has been replaced by hunspell.
-- Niko Wenselowski <n.wenselowski@uib.de> Wed, 11 Apr 2019 18:22:25 +0100
l-desktop 4.1.0.4-1 ; stable ; urgency=low
* Further improve handling for English translation packages.
-- Niko Wenselowski <n.wenselowski@uib.de> Wed, 11 Apr 2019 18:12:25 +0100
l-desktop 4.1.0.3-1 ; stable ; urgency=low
* Improve handling for english libreoffice help packages under Debian / Ubuntu.
-- Niko Wenselowski <n.wenselowski@uib.de> Wed, 11 Apr 2019 17:56:25 +0100
l-opsi-server (4.1.1.10-5); stable; urgency=low
* opsi 4.1: Do not abort on UCS 4.3.
-- Niko Wenselowski <n.wenselowski@uib.de> Wed, 12 Apr 2019 14:59:10 +0100
l-opsi-server (4.1.1.10-4); stable; urgency=low
* opsi 4.1: Fix UCS repo selection for UCS 4.4.
-- Niko Wenselowski <n.wenselowski@uib.de> Wed, 12 Apr 2019 13:45:13 +0100
l-opsi-server (4.1.1.10-3); stable; urgency=low
* Remove support for UCS 4.2 in opsi 4.1 and fix support for UCS 4.4.
-- Niko Wenselowski <n.wenselowski@uib.de> Wed, 12 Apr 2019 13:25:29 +0100
l-opsi-server (4.1.1.10-2); stable; urgency=low
* 4.1: UCS 4.4; corrected typos
-- Mathias Radtke <m.radtke@uib.de> Fri, 12 Apr 2019 11:00:00 +0100
l-opsi-server (4.1.1.10-1); stable; urgency=low
* 4.1: UCS 4.4 support added
-- Mathias Radtke <m.radtke@uib.de> Wed, 03 Apr 2019 11:00:00 +0100
l-opsi-server (4.1.1.9-7); stable; urgency=low
* 4.1: added apt-get option to keep old config instead of asking
-- Mathias Radtke <m.radtke@uib.de> Wed, 20 Mar 2019 14:30:00 +0100
opsi-script-test (4.12.1.0-1) stable; urgency=low
* macos tests
* recursive local functions 4.12.0.36
* fixes for linux
* urlparser
* xml2
* regex
* netcalc
* DirectoryExists
* ExtractFileName
* filestest now in subscript
* changes for license test (opsi-script-test)
* wmitest
* todo: adapt licenesdb for changes for license test (opsi-script-test)
-- detlef oertel <d.oertel@uib.de> Thu, 24 Jan 2019 15:00:00 +0200
opsi-template-with-admin (4.1.0.0-2) stable; urgency=low
* fixed shell shebang in preinst and postinst
* changelog now in changelog.txt
-- detlef oertel <d.oertel@uib.de> Tue, 30 Apr 2019 15:00:00 +0000
opsi-client-agent (4.1.0.0-29) stable; urgency=low
* opsi-script 4.12.1.2
-- Detlef Oertel <d.oertel@uib.de> Fri, 26 Apr 2019:15:00:00 +0200
opsi-client-agent (4.1.0.0-28) stable; urgency=low
* opsiclientd 4.0.96
-- Erol Ueluekmen <e.ueluekmen@uib.de> Thu, 18 Apr 2019:01:44:00 +0200
opsi-client-agent (4.1.0.0-27) stable; urgency=low
* opsiclientd 4.0.95
* fixed opsi-deploy-client-agent
-- Detlef Oertel <d.oertel@uib.de> Thu, 17 Jan 2019:15:00:00 +0200
swaudit (4.1.0.0-3) stable; urgency=low
* new product property win10subversion
values: ["win10osbuild", "hklmproductid"]
default: ["hklmproductid"]
hklmproductid show begin of HKLM\Software\Mscrosoft\Windows NT\CurrentVersion] ProductId" for example 00330-71317
win10osbuild shows OS Build as found on https://docs.microsoft.com/en-us/window ... nformation on on Win10 , Win 2016 , Win2019 from HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion", "CurrentBuild" and HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion", "UBR"
-- bardo wolf <b.wolf@uib.de> Mon, 01 Apr 2019 12:26:01 +0100
jedit_5.5.0-6 stable; urgency=low
* -reuseview
-- b.wolf <b.wolf@uib.de> Tue, 16 Apr 2019
jedit_5.5.0-5 stable; urgency=low
* use generic launcher for startup instead of jedit.bat
-- b.wolf <b.wolf@uib.de> Tue, 09 Apr 2019
jedit_5.5.0-4 stable; urgency=low
* java version changed since avast blocked the java.exe
-- r.roeder <r.roeder@uib.de> Tue, 26 Feb 2019
jedit_5.5.0-3 stable; urgency=low
* use jar-Installer on windows bundled with sapmachine 11.0.2 x64, jre 8u202 Oracle
* use jedit.bat for start on windows
* merge l-jedit with jedit
* removed properties gui_language,start_server
* on ubuntu bionic and cosmic : use deb-package
-- b.wolf <b.wolf@uib.de> Tue, 30 Jan 2019
jedit_5.5.0-2 stable; urgency=low
* fixes failed install with openjdk
-- r.roeder <r.roeder@uib.de> Tue, 18 Dec 2018 15:00:00 + 0100
config-win10 (4.1.1-6);. stable; urgency=low
* removing key SetDisableUXWAccess when enabling updates
* new property: no_new_app_install_notification
-- Mathias Radtke <m.radtke@uib.de> Tue, 07 May 2018 10:41:00 +0200
opsi-linux-client-agent (4.1.0.17-1) stable; urgency=medium
* update opsi-script to 4.12.1.3
-- d.oertel <d.oertel@uib.de> Tue, 14 May 2019 15:00:00 + 0100
opsi-linux-client-agent (4.1.0.16-1) stable; urgency=medium
* update opsi-script to 4.12.1.2
-- d.oertel <d.oertel@uib.de> Thu, 02 May 2019 15:00:00 + 0100
opsi-linux-client-agent (4.1.0.15-1) experimental; urgency=medium
* Updated opsiclientd binaries.
-- Niko Wenselowski <n.wenselowski@uib.de> Tue, 09 Apr 2019 17:19:39 +0100
opsi-linux-client-agent (4.1.0.14-1) experimental; urgency=medium
-- Niko Wenselowski <n.wenselowski@uib.de> Tue, 09 Apr 2019 11:13:10 +0100
opsi-linux-client-agent (4.1.0.13-1) stable; urgency=medium
* Added support for UCS 4.4
-- Mathias Radtke <m.radtke@uib.de> Tue, 02 Apr 2019 14:25:00 +0200
opsi-linux-client-agent (4.1.0.12-1) stable; urgency=medium
* added dependency to desktop-file-utils
* update opsi-deploy-client-agent (nw)
-- d.oertel <d.oertel@uib.de> Mon, 21 Jan 2019 15:00:00 + 0100
opsi-linux-client-agent (4.1.0.11-2) testing; urgency=medium
* updated opsi-deploy-client-agent to 4.1.0.1.
-- Niko Wenselowski <n.wenselowski@uib.de> Thu, 10 Jan 2019 18:10:57 +0100
ubuntu16-04 (4.1.0.1-3) testing; urgency=low
* kernel/initrd updated
-- Mathias Radtke <m.radtke@uib.de> Mon 20 May 2019 14:00:00 +0200
debian9 (4.1.0.2-5) testing; urgency=low
-- Mathias Radtke <m.radtke@uib.de> Mon 29 Apr 2019 07:42:00 +0100
win10-sysprep-app-update-blocker (4.1.0.0-1) stable; urgency=medium
* Changed name of product from opsi-wim-capture-helper to win10-sysprep-app-update-blocker
-- d.oertel <d.oertel@uib.de> Di, 21 May 2019 16:39:50 +0200
opsi-wim-capture-helper (4.1.0.0-1) stable; urgency=medium
* initial by opsi-setup-detector
* This stops apps from updating and windows store from auto installing apps.
* ; https://blogs.technet.microsoft.com/mni ... rep-happy/
* ; in comment from PeteBC
-- d.oertel <d.oertel@uib.de> Di, 16 Apr 2019 16:39:50 +0200
windows (4.1.0.0-16) stable; urgency=low
* unattend: removed windows defender registry manipulation
-- Mathias Radtke <m.radtke@uib.de> Tue, 07 May 2019 14:00:00 +0200
