Dear opsi users,
we have now some new packages for opsi 4.0 and opsi 4.1 in testing.
For the new opsi extension opsi-vhd-reset which is desingned for schools or other kinds of learning computers,
there is a new product which controls the upgrade process of a parent vhd: 'opsi-vhd-auto-upgrade'
(have a look at the manual).
All the Windows NT6 netboot products have got some bugfixes that deals with multidisk mode problems.
The processing of wim Images was reviewed. So we got a enhanced opsi-wim-capture product
as well asa totaly new opsi-local-image-wim-capture which is build nearly the same way.
The manuals opsi-getting-started*, opsi-manual*, opsi-winst-manual are
in new versions in the testing section.
As testing we publish:
Windows netboot packages
NT6 4.1.0.0-5
Windows localboot packages
* opsi-wim-capture (4.1.0.1-1) (require opsi-winst 4.12.0.15)
* opsi-winst 4.12.0.15
* jedit_5.4.0-1
* windows10-upgrade 17.09-8
opsi-linux packages
Linux netboot packages
* debian9 (4.1.0.0-1)
Linux localboot packages
* opsi-linux-client-agent 4.1.0.1-1
opsi-local-image / opsi-vhd:
* opsi-vhd-auto-upgrade (4.1.0.0-1) (require opsi-winst 4.12.0.15)
* opsi-local-image-wim-capture 4.1.0.1-1 (require opsi-winst 4.12.0.15)
(Diese Produkt ersetzt die Produkte:
opsi-local-image-capture, opsi-local-image-sysprep)
* opsi-local-image-ubuntu (4.1.0.0-2)
* opsi-local-image-restore (4.1.0.0-3)
* opsi-local-image-prepare (4.1.0.0-2)
Server packages:
opsi 4.0:
* opsi-depotserver 4.0.7.3-3
* opsi4ucs 4.0.7.5-11
* opsiconfd 4.0.7.14-2
* opsipxeconfd 4.0.7.9-2
* python-opsi 4.0.7.57-1
opsi 4.1:
* opsi-server 4.1.1.4-10
* opsi4ucs 4.1.1.4-12
* opsiconfd 4.1.1.10-4
* opsipxeconfd 4.1.1.8-2
* python-opsi 4.1.1.29-1
Misc:
* the product opsi-set-win-uac moved to the contribute area.
* the product opsi-local-image-opensuse13-2  was removed
* the product opsi-local-image-capture was removed
* the product opsi-local-image-sysprep was removed
detlef oertel
Changelogs:
opsi-winst/opsi-script (4.12.0.15) stable; urgency=low
  * oswebservice: getMapOfLoginscripts2Run: fix: check not only for productId but also for productVersion and PackageVersion
  * oswebservice: getMapOfLoginscripts2Run: change logging to log_prog
-- Detlef Oertel <d.oertel@uib.de>  Fri, 09 Mar 2018:15:00:00 +0200
opsi-winst/opsi-script (4.12.0.14) stable; urgency=low
  * osparser: evaluateBoolean: sendlog: switch log append mode on
      in order to avoid that a final log removes this one
  * new function : getSubListByMatch(<search string>, <target list>) :stringlist
  * new function : getSubListByMatch(<search list>, <target list>) :stringlist
  * new function : getSubListByContaining(<search string>, <target list>) :stringlist
  * new function : getSubListByContaining(<search list>, <target list>) :stringlist
  * new function : getSubListByKey(<search string>, <target list>) :stringlist
  * new function : getSubListByKey(<search list>, <target list>) :stringlist
  * new function : getKeyList(<list>) :stringlist
-- Detlef Oertel <d.oertel@uib.de>  Tue, 13 Feb 2018:15:00:00 +0200
opsi-winst/opsi-script (4.12.0.13-2) stable; urgency=low
  * uib_bootutils: DefFunc enablePEPartition: use powershell if possible
-- Detlef Oertel <d.oertel@uib.de>  Wed, 07 Dec 2018:15:00:00 +0200
jedit_5.4.0-1 stable; urgency=low
   * update to 5.4 (require java >= 8)
   * opsi-script.xml for opsi-script 4.12.0.15
-- d.oertel <d.oertel@uib.de> Tue, 13 Mar 2018 15:00:00 + 0100
opsi-linux-client-agent (4.1.0.0-1) stable; urgency=medium
  * opsi-script 4.12.0.14
  * opsiscriptstarter 4.1.0. (fall back to smb1)
-- d.oertel <d.oertel@uib.de> Mon, 05 Mar 2018 15:00:00 + 0100
opsi-linux-client-agent (4.0.7.20-1) stable; urgency=low
  * opesnSuse Leap42.X: starting sshd in setupscript
 -- Mathias Radtke <m.radtke@uib.de> Tue, 19 Dec 2017 15:25:00 +0100
opsi-linux-client-agent (4.0.7.19-1) stable; urgency=medium
  * 	openSUSE Leap 42.2: zypper install librsync2
  * 	Suse 13.2: removed
-- Bardo Wolf <b.wolf@uib.de> Thu 07 Nov 2017
opsi-linux-client-agent (4.0.7.18-1) stable; urgency=medium
  * UCS: using univention-installer instead of apt-get
-- Mathias Radtke <m.radtke@uib.de> Mon, 06 Nov 2017 10:48:00 +0100
opsi-vhd-auto-upgrade (4.1.0.0-1) stable; urgency=low
	* initial
	* derivated from opsi-vhd-tester
	* priority: -97
	* switch opsi-vhd-tester to none
-- detlef oertel <d.oertel@uib.de>  Mon, 05 Feb 2018 15:00:00 +0200
opsi-wim-capture (4.1.0.1-1) stable; urgency=low
  * windows 7 tools removed
  * all imagex commands migrated to wimlib
  * also supports .esd (not only .wim) via wimlib (imagex)
  * remove winst32/dummy.exe (replaced by test32bit.exe
  * code cleanup
  * opsisetuplib from 5.2.2018
  * require opsi-winst 4.12.0.14
  * new property force_clear_lock
-- detlef oertel <d.oertel@uib.de>  Wed, 07 Feb 2018 15:00:00 +0000
opsi-local-image-capture (4.1.0.1-1) stable; urgency=low
  * merged from:
    opsi-local-image-capture (4.0.7.2-2)
  * code cleanup
windows (4.1.0.0-5) stable; urgency=low
  * nt6_repartition.opsiscript: fix if datapartition and remove pe
  * nt6_repartition.opsiscript: fix for win7 (no ps get-partition)
  * nt6_repartition : fix: get uuid from diskpart output parsing
  * nt6_repartition: fix loop bug in older opsiscript in calling subhide2
  * nt6_repartition: fix in call unhidepart.txt
  * nt6_repartition: fix uuid handling
  * nt6.py: diskpart.txt: del pe: change sequence of datapartition handling
windows10-upgrade (17.09-8) stable; urgency=low
  * requiredWinstVersion >= 4.12.0.8
-- bardo wolf <b.wolf@uib.de>   26 Feb 2018
windows10-upgrade (17.09-7) stable; urgency=low
  * fixes #3386 windows10-upgrade uac-level according https://forum.uib.de/viewtopic.php?f=7& ... 1&start=10
-- bardo wolf <b.wolf@uib.de>   22 Feb 2018
windows10-upgrade (17.09-6) testing; urgency=low
  * if exists use c:\opsi.org\applog instead of c:\tmp
-- bardo wolf <b.wolf@uib.de>   21 Feb 2018
windows10-upgrade (17.09-5) testing; urgency=low
  * try to fix check if already targetversion installed
-- bardo wolf <b.wolf@uib.de>   20 Feb 2018
opsi-local-image (4.1.0.0-2) testing; urgency=low
  * preinst/postinst: removed opsi version check
  * call getUuidFromPartitionDevice from opsisetuplib
-- Mathias Radtke <m.radtke@uib.de> Wed Feb  7 07:50:10 2018 +0200
debian9 (4.1.0.0-1) testing; urgency=low
  * Kernel update
-- Mathias Radtke <m.radtke@uib.de> Tue Mar 13 13:18:00 2018 +0100
opsi-local-image-restore (4.1.0.0-3) stable; urgency=low
  * conserve opsi-mete-data of opsi-local-image-wim-capture
-- detlef oertel <d.oertel@uib.de>  Thu, 15 Mar 2018 15:00:00 +0200
opsi-server (4.1.1.4-10) stable; urgency=medium
  * based on opsi-depotserver 4.0.7.3-3.
 -- Niko Wenselowski <n.wenselowski@uib.de>  Tue, 09 Mar 2018 13:34:21 +0100
opsi-depotserver (4.0.7.3-3) stable; urgency=medium
  * Quote shell variables to avoid possible side effects.
  * postinst: Do not fail on renaming fileadmingroup.
 -- Niko Wenselowski <n.wenselowski@uib.de>  Mon, 09 Mar 2018 13:05:33 +0100
opsi4ucs (4.1.1.4-12) stable; urgency=medium
  * Based on 4.0.7.5-11.
 -- Niko Wenselowski <n.wenselowski@uib.de>  Fri, 02 Mar 2018 16:49:53 +0100
opsi4ucs (4.0.7.5-11) testing; urgency=medium
  * Display a message if reloading samba fails.
  * Use systemctl for samba reloads on UCS 4.2.
 -- Niko Wenselowski <n.wenselowski@uib.de>  Fri, 02 Mar 2018 13:43:40 +0100
opsiconfd (4.1.1.10-4) stable; urgency=medium
  * Based on opsiconfd 4.0.7.14-2.
  * postinst: Assuming that systemctl exists.
 -- Niko Wenselowski <n.wenselowski@uib.de>  Fri, 09 Mar 2018 14:01:37 +0100
opsiconfd (4.0.7.14-2) stable; urgency=medium
  * RPM: prevent possible shell syntax errors.
  * postinst: Added quotation around variables to avoid side effects.
 -- Niko Wenselowski <n.wenselowski@uib.de>  Tue, 09 Mar 2018 12:33:07 +0100
opsipxeconfd (4.1.1.8-2) stable; urgency=medium
  * Based on opsipxeconfd 4.0.7.9-2.
  * Assuming systemctl is present and executable.
 -- Niko Wenselowski <n.wenselowski@uib.de>  Fri, 09 Mar 2018 14:25:13 +0100
opsipxeconfd (4.0.7.9-2) stable; urgency=medium
  * RPM: only use restart macro on SUSE distros.
  * RPM: Avoid possible bash syntax error.
 -- Niko Wenselowski <n.wenselowski@uib.de>  Fri, 09 Mar 2018 11:55:23 +0100
python-opsi (4.1.1.29-1) stable; urgency=medium
  * OPSI.Util.Task.Certificate: use os.urandom instead of OpenSSL.rand
    because OpenSSL.rand has been removed in current versions.
 -- Niko Wenselowski <n.wenselowski@uib.de>  Fri, 09 Mar 2018 15:40:23 +0100
python-opsi (4.0.7.57-1) testing; urgency=medium
  * OPSI.Backend.MySQL: In case the MySQL server goes away during the
    execution of a query the retry will not deadlock.
 -- Niko Wenselowski <n.wenselowski@uib.de>  Fri, 23 Feb 2018 12:58:25 +0100
python-opsi (4.0.7.56-1) testing; urgency=medium
  * OPSI.Backend.MySQL: Creation of connection pool will wait for the lock
    in a non-blocking fashion.
 -- Niko Wenselowski <n.wenselowski@uib.de>  Tue, 20 Feb 2018 13:34:45 +0100
python-opsi (4.0.7.55-1) stable; urgency=medium
  * OPSI.Backend.Backend: configState_insertObject and
configState_updateObject
    do not fail anymore when called with a dict as parameter.
 -- Niko Wenselowski <n.wenselowski@uib.de>  Fri, 02 Feb 2018 14:32:28 +0100
python-opsi (4.0.7.54-1) stable; urgency=medium
  * OPSI.Backend.MySQL: Avoid possible deadlock situation.
 -- Niko Wenselowski <n.wenselowski@uib.de>  Thu, 01 Feb 2018 15:27:03 +0100
python-opsi (4.0.7.53-1) testing; urgency=medium
  * OPSI.Backend.MySQL: Fix a bug in the handling of the connection pool
    that would lead to opening too many connections to the mysql server.
  * OPSI.Backend.MySQL: Correctly defining a special version of
    productProperty_updateObject.
 -- Niko Wenselowski <n.wenselowski@uib.de>  Thu, 04 Jan 2018 15:05:09 +0100
opsi-local-image-prepare (4.1.0.0-2) stable; urgency=low
  * del grub on disk before restore
-- detlef oertel <d.oertel@uib.de>  wed, 07 Feb 2018 15:00:00 +0200
									New testing packages for opsi 4.0 and 4.1
