opsi WIM Capture in 4.0.6 stable - new opsi products in testing
News and announcements
Dear opsi users,
We hereby publish a series of new packages, manuals and fixes as stable and testing.
This includes especially the new opsi extension opsi-wim-capture.
The description for opsi-wim-capture, and the required activation steps
can be found in opsi-manual in section 9.2.
As stable we publish:
Localboot:
* Opsi-client-agent (4.0.6.3-11)
* Opsi-winst / opsi script (4.11.5.18-1)
* Opsi-wim-capture_4.0.6.1-3
Netboot:
* New for opsi-wim-capture:
* Win7-captured
* Win7 x64 captured,
* Win81-captured,
* Win81-x64-captured,
* Win10-captured,
* Win10-x64-captured,
Manuals:
* Opsi-getting-started
* Opsi-manual
* Opsi-support-matrix
* Opsi-winst-manual
* Opsi-winst-reference-card
As testing we publish:
Localboot:
* opsi-winst/opsi-script (4.11.5.19-1)
* opsi-client-agent (4.0.6.3-12)
opsi-local-image:
* opsi-local-image-opensuse13-2 (4.0.6.2-3)
* opsi-local-image-ubuntu (4.0.6.1-2)
* opsi-local-image windows NT6 (4.0.6.1-4)
Server packages:
* opsi-linux-bootimage (20160322-1)
The opsi products for testing can be found at:
http://download.uib.de/opsi4.0/testing/opsi-v406/
The testing server packages are in the Testing branch of the opsi repositories:
http://download.opensuse.org/repositori ... 0-testing/
As always, kind regards
detlef oertel
Changelogs:
opsi-winst/opsi-script (4.11.5.19) stable; urgency=low
* osmain: BuildPC: terminate after exception in BuildPC: final ; references #1820
* oswebservice: finishOpsiConf: catch exception at backend_exit ; fixes #1820
-- Detlef Oertel <d.oertel@uib.de> Mon, 04 Apr 2016:15:00:00 +0200
opsi-winst/opsi-script (4.11.5.18-1) stable; urgency=low
* Windows upgrade to indy 10.6.2 (Indy10_5345) for openssl 1.0.2g
* downgrade to openssl 1.0.2f
-- Detlef Oertel <d.oertel@uib.de> Thu, 09 Feb 2016:15:00:00 +0200
opsi-winst/opsi-script (4.11.5.17-2) stable; urgency=low
* update to openssl 1.0.2g
* touch auf winst32.exe
-- Detlef Oertel <d.oertel@uib.de> Fri, 04 Mar 2016:15:00:00 +0200
opsi-winst/opsi-script (4.11.5.17) stable; urgency=low
* osparser: savetextfile: call FuncSaveToFile ; fixes #1997
* Merge from 4.11.6.1 for Linux:
* osconf,osmain: change depotdrive for linux from /mnt to /media/opsi_depot
* osmain: new command line parameter: 'credentialfile' for username, password and sessionid in format:
username=<username>
password=<password>
sessionid=<sessionid>
If the parameter 'credentialfile' is used all thre parameter will be used from the file and
the parameters : username, password and sessionid will be ignored
* osmain: BuildPC: create flag files in /var/run/opsiclientd for shutdown or reboot
execute reboot only if no opsiclientd in processlist
* opsiscript.lpr / winst.lpr replace defaulttranslator by lcltranslator
* osmain: (GUI) GetParameter: new parameter: lang <2 letter lang code>
is set to lcltranslator.SetDefaultLang
opsi-client-agent (4.0.6.3-12) stable; urgency=low
* Updated opsi-deploy-client-agent to 4.0.6.14. (nw)
* Updated opsi-script to 4.11.5.19 (do)
-- Niko Wenselowski <n.wenselowski@uib.de> Thu, 05 Apr 2016 10:46:25 +0100
opsi-client-agent (4.0.6.3-11) stable; urgency=low
* change to opsi-script 4.11.5.18 (openssl 1.0.2f , can handle openssl 1.0.2g)
* fixes at importing productOnClient from wim-capture and oli-capture
* calling sc.exe with full path ; fixes #2085
* copy ssl DLLs from openssl dir (not from opsi-script dir)
-- Detlef Oertel <d.oertel@uib.de> Tue, 22 Mar 2016:15:00:00 +0200
opsi-client-agent (4.0.6.3-10) stable; urgency=low
* update to opsi-script 4.11.5.18 (with openssl 1.0.2g)
* go back to openssl 1.0.2f until opsiclientd can handle 1.0.2g
-- Detlef Oertel <d.oertel@uib.de> Thu, 10 Mar 2016:15:00:00 +0200
opsi-client-agent (4.0.6.3-9) stable; urgency=low
* Updated opsi-deploy-client-agent to 4.0.6.13.(nw 26.2.16)
opsi-client-agent (4.0.6.3-8) stable; urgency=low
* integrate restore of product on client from wim-capture
* $LogDir = %opsiLogDir%
* update to opsi-winst 4.11.5.16
-- Detlef Oertel <d.oertel@uib.de> Mon, 01 Feb 2016:15:00:00 +0200
opsi-wim-capture (4.0.6.1-3) stable; urgency=low
* Added check for WinPE Partition
-- detlef oertel <d.oertel@uib.de> Wed, 23 Mar 2016 15:00:00 +0000
opsi-wim-capture (4.0.6.1-2) stable; urgency=low
* added locking file opsi-wim-capture.lock in base directory of target product
* file install.esd accepted as possible append file
* update to wimlib 1.9
-- detlef oertel <d.oertel@uib.de> Mon, 24 Feb 2016 15:00:00 +0000
opsi-wim-capture (4.0.6.1-1) stable; urgency=low
* Project copied from: opsi-local-image-sysprep_4.0.6.1-1.opsi
* Merged with opsi-local-image-capture
-- detlef oertel <d.oertel@uib.de> Mon, 28 Dec 2015 19:18:21 +0000
opsi-local-image-opensuse13-2 (4.0.6.2-3) stable; urgency=low
opsi-local-image-ubuntu (4.0.6.1-2) stable; urgency=low
opsi-local-image windows NT6 (4.0.6.1-4) stable; urgency=low
* opsisetuplib.py: added NVME Device path in getPartitionDevicePath()
-- Mathias Radtke <m.radtke@uib.de> Mon, 04 Apr 2016 13:50:00 +0200
opsi-linux-bootimage (20160322-1) testing; urgency=medium
* added python-opsi_4.0.6.45-1
-- Mathias Radtke <m.radtke@uib.de> Tue, 22 Mar 2016 13:55:35 +0100
opsi-linux-bootimage (20160210-2) experimental; urgency=medium
* added testdisk package into bootimage
-- Mathias Radtke <m.radtke@uib.de> Wed, 10 Feb 2016 11:38:35 +0100
opsi-linux-bootimage (20160210-1) UNRELEASED; urgency=medium
* removed positive default link feedback
