Sehr geehrte opsi-Anwender,
hiermit veröffentlichen wir eine Reihe von fixes als stable.
Bei den Serverpaketen kann es eine Zeitlang dauern bis diese im stable Repository auf allen Mirrors verfügbar sind.
Als stable Veröffentlichen wir:
* opsi-client-agent (4.0.6.3-6) (SSL-Update und Fixes)
* hwaudit (4.0.6.1-3) (SSL-Update)
* opsi-winst/opsi-script (4.11.5.14-2) (SSL-Update)
* opsi-linux-client-agent (4.0.5.10-1)
* netboot NT6: windows (4.0.6.2-2) (fixes for driver integration)
* netboot opsi-local-image NT6: windows (4.0.6.1-3) (fixes for driver integration)
* opsi-linux-bootimage (20151217-1)
Mit freundlichen Grüßen
e. ülükmen
Changelogs:
Win*
windows (4.0.6.2-2) stable; urgency=low
* setup.py: Only extend sytempartition after deletion of winpe if dataPartitionCreate or (windowsPartitionSize = "100%")
-- Detlef Oertel <d.oertel@uib.de> Wed, 16 Dec 2015:15:00:00 +0200
windows (4.0.6.2-1) stable; urgency=low
* updated create_driver_links.py for better link handling.
* setup.py: Fix reference to undefined variable.
* show_drivers.py: Fixed symbolic links in byAudit (fixes #1569); Fixed problem: directorynames ending with . or
whitespace
-- Erol Ueluekmen <e.ueluekmen@uib.de> Thu, 10 Dec 2015 22:25:00 +0200
opsi-local-image:
windows (4.0.6.1-3) stable; urgency=low
whitespace
opsi-local-image-capture (4.0.6.1-4) stable; urgency=low
* fix default for opsi_depot_rw_host (fix hn not defined error)
* new property: checkdisk_before_capture (Default=false)
* update to openssl 1.0.2e
-- detlef oertel <d.oertel@uib.de> Mon, 14 Dec 2015 15:00:00 +0200
opsi-local-image-capture (4.0.6.1-3) stable; urgency=low
* preferr serviceUrl from config.ini
-- detlef oertel <d.oertel@uib.de> Wed, 20 Oct 2015 15:00:00 +0200
hwaudit (4.0.6.1-3) stable; urgency=low
* fixes #1886 update to openssl 1.0.2e in lib subdirectory ( ssleay32.dll libeay32.dll )
-- Bardo Wolf <b.wolf@uib.de> 08 Dec 2015
opsi-winst/opsi-script (4.11.5.14-2) stable; urgency=low
-- Detlef Oertel <d.oertel@uib.de> Mo, 14 Dec 2015:15:00:00 +0200
opsi-client-agent (4.0.6.3-6) stable; urgency=low
* Updated opsi-deploy-client-agent to 4.0.6.11. (nw)
* update getmsversioninfo (for win10)
* call subconfig from setup script and disable update
* update script checks if it match to installed Version
* uninstall entry for windows now references uninstall.opsiscript (instead of uninstall.ins)
opsi-linux-client-agent (4.0.5.10-1) stable; urgency=low
* update to opsi-script/opsi-script-nogui 4.11.5.15
* disabled winbind at jessie ..(Bug in winbind 4.1.7: https://bugzilla.samba.org/show_bug.cgi?id=10604 )
-- d.oertel <d.oertel@uib.de> Thu, 17 Sep 2015 15:00:00 + 0100
opsi-linux-client-agent (4.0.5.9-3) stable; urgency=low
* fix systemd opsiclientd startscript: # Required-Start: $network
-- d.oertel <d.oertel@uib.de> Tue, 27 Oct 2015 15:00:00 + 0100
config-win10 (4.0.6-5) stable; urgency=low
* Added new property to disable update search
-- m.radtke <m.radtke@uib.de> Tue, 03 Nov 2015 14:30:00 + 0100
opsi-depotserver (4.0.6.4-2) stable; urgency=low
* Version bumped to force init-current-config run.
-- Erol Ueluekmen <e.ueluekmen@uib.de> Thu, 17 Dec 2015 16:18:22 +0100
opsi-linux-bootimage (20151217-1) testing; urgency=medium
* Hyper-V broken drivers fixed (network & storage)
* integrated UCS hotfix (opsi-linux-bootimage_20151125-3)
-- Mathias Radtke <m.radtke@uib.de> Thu, 17 Dec 2015 14:15:51 +0100
Neue Pakete für opsi 4.0.6 in Stable
Re: Neue Pakete für opsi 4.0.6 in Stable
kann mir vielleicht jemand die sha256sum dieses Bootimages zur Verfügung stellen?
Danke
SirTux
Danke
SirTux
Checksums-Sha1:
7385eb9f0e67ef1d715f1666f78af418adc5cd6b 212284479 opsi-linux-bootimage_20151217-1.tar.gz
Checksums-Sha256:
f3438c930f792565c6f5fc60c52f4a4221cf1666396b9793a56000c077d4afe2 212284479 opsi-linux-bootimage_20151217-1.tar.gz
Files:
a588d66e3d949f8e163ba398e24a5f04 212284479 opsi-linux-bootimage_20151217-1.tar.gz
in Zukunft bitte einen eigenen Thread öffnen.
Für Fragen haben wir ja das Support Unterforum
